LS to EG Brake Swap
92_luder
LS to EG Brake Swap
Post by 92_luder »
I've looked all over but cant find a straight answer......
Are the trailing arms from a sedan teg the same as the coupe teg...and are they the same as the trailing arms on the civic hatch...
.....and in doing a rear disc swap off of an ls/rs onto a eg hatch i need the rs prop valve so the fluid is distributed adequately for the four discs and it has to be rs since its non-abs?
eh2_Erik
LS to EG Brake Swap
Post by eh2_Erik »
They should be the same, and yes, the RS prop valve is what you need.
Now s13_Erik
92_luder
LS to EG Brake Swap
Post by 92_luder »
eh2_Erik;287855 wrote:They should be the same, and yes, the RS prop valve is what you need.
i can keep the eg master cylinder and the rest of the component...all i need is the rear trailing arm(complete) and an RS proportioning valve?
eh2_Erik
LS to EG Brake Swap
Post by eh2_Erik »
I did the rear disc swap on my first civic hatch. I just threw it on and drove, but i read that if you want the braking attributes of an integra, you need the front and rear setup, prop valve but thats all i know. I don't know off the top of my head if the booster is needed. I think Muha would know tho.
Now s13_Erik
92_luder
LS to EG Brake Swap
Post by 92_luder »
eh2_Erik;287870 wrote:I did the rear disc swap on my first civic hatch. I just threw it on and drove, but i read that if you want the braking attributes of an integra, you need the front and rear setup, prop valve but thats all i know. I don't know off the top of my head if the booster is needed. I think Muha would know tho.
thanks man thats awesome, gotta love a str8 answer
