Anyone make wheels spacers?
muha22752
Post by muha22752 »
looking for some to make me some wheel spacers. 20mm
I know, thats alot but the offset on these new wheels sucks. lool, spacers will be cheaper than anything else for now.
umadbro?
"You have to pay to play"
W.K.D
1995 Civic Si 1.6 (Sold)
2003 Audi A4 1.8t (sold)
eh2_Erik
Post by eh2_Erik »
You'll need extended wheel studs if you're planning on spacing out 20mm. Or buy bolt on spacers. The offset will change substantially if you buy wider barrels tho. So you must figure out the Final offset will calculate out to.
Now s13_Erik
muha22752
Post by muha22752 »
yap, just want to see it someone can make them for me rather than buying them off of the web. I already have it offset figured out. 20mm buring me to 49mm difference from my esm's.
umadbro?
W.K.D
delslo
Post by delslo »
I used plywood
muha22752
Post by muha22752 »
I was thinking about duck tape, but plywood might work.
umadbro?
W.K.D
Post by Capt'n Obvious »
ebay sells extended studs and 20mm spacers as a set and also probly have 1 inch with studs in em that are held onto your stock studs with lugnuts
i have 8mm thats the largest i would go on stock studs
