koni yellows n i got questions
DakMathews
i got an 01 civic ex coupe that needs new shocks. i got the koni package from tire rack that has 4 koni yellows and 4 lowering springs in it and got it here and the directions are telling me to cut the strut housing n put the new shock in it. i was wondering if anyone has done this before and could tell me if im gunna have problems or if this is a good idea since i just got the car and dont want to mess anything up on it.
Midori
yeah i saw a write up on this a long time ago, since konis dont have spring perches your supposed to basically cut the shocks in half and put the konis inside of them lol, I would never attempt it
-'11 Taffeta White CR-V
gsrauto98
I was told you can buy spring perches for the koni's. I have not exactly looked though
Before you cut the shock drill a drain hole and drain the oil or you run the risk of catching the oil on fire from the heat of cutting.
send the springs back and get coilovers
CRX91
dakota call jake and talk to his brother im shure he would do it.
DakMathews
yea thanks guys adrenaline n st peters said they would help me out on it. ive had them for over a month n i dont think i can send them back now
