cut a top hat?
crx08
cut a top hat?
Post by crx08 »
I have tried to cut these top hats I pulled from a junkyard since GC doesn't make extended top hats for the accords. I was using a hack saw for 20-30 mins and got no where. any one have any other suggestions on a quicker way to cut it off? or maybe have access to a band saw?
stl-imports.com/forums
cut a top hat?
Grinder + cut off disk.
99PreludeSh
cut a top hat?
Post by 99PreludeSh »
Waffles;224768 wrote:Grinder + cut off disk.
just about to post that. If you need a grinder to borrow let me know I have one.
crx08
cut a top hat?
Post by crx08 »
good thinking
99PreludeSh;224770 wrote:just about to post that. If you need a grinder to borrow let me know I have one.
I might when I get time.
cut a top hat?
Post by stolle »
hole saw just a little bit bigger than the top.
either that or just get one the same size as the tubing your going to use perfect round hole to weld on :)
Team NOCO Crew Member #2
cut a top hat?
Post by Capt'n Obvious »
fuck gc i got mine off ebay for 50 bux see if they make em for accords
