cut a top hat?
crx08
cut a top hat?
I have tried to cut these top hats I pulled from a junkyard since GC doesn't make extended top hats for the accords. I was using a hack saw for 20-30 mins and got no where. any one have any other suggestions on a quicker way to cut it off? or maybe have access to a band saw?
stl-imports.com/forums
99PreludeSh
cut a top hat?
just about to post that. If you need a grinder to borrow let me know I have one.Waffles;224768 wrote:Grinder + cut off disk.
crx08
cut a top hat?
good thinkingWaffles;224768 wrote:Grinder + cut off disk.
I might when I get time.99PreludeSh;224770 wrote:just about to post that. If you need a grinder to borrow let me know I have one.
cut a top hat?
hole saw just a little bit bigger than the top.
either that or just get one the same size as the tubing your going to use perfect round hole to weld on
cut a top hat?
fuck gc i got mine off ebay for 50 bux see if they make em for accords
