Immovable Bolt. HELP
bemberg2
Post by bemberg2 »
So there is this bolt. It NEEDS to come off so I can remove my rear struts and replace my springs, but refuses to budge. The bolt is on the control arm and is the closest to the brake drum. I have tried 1/2" breaker bar, impact wrench, heating it up w/ torch and then wrench/breaker bar, NOTHING. Does anyone have any advice or prove their manliness by getting it off? Let me know if you have tips or know if i can remove the strut/spring by pivoting the member out of the car the other way, by removing the upper bolt connecting the control arm to the middle part of the car. THANKS!
bemberg2
Post by bemberg2 »
Thanks for the links. This sounds like a really common problem. I'll do some searching for LCAs and some more money.
Yeah, most people end up breaking the LCA bolt. I think I was one of the few lucky ones that didnt when I had my CRX back in the day.
Post by Capt'n Obvious »
impact driver 6 bucks at harbor freight not a bolt that mine could not loosen
JmBurton
Post by JmBurton »
Lmfao i had this problem today trying to put some springs on.. i just dooshed it with PB blaster allllllllll day and i finally got it out couple hours ago lol... just takes time, PB blaster + hammer works awsome.. lol
kleancut
Post by kleancut »
notorious problemo. karate chop that mutha, and get a new bolt.
I love Portishead.
delslo
Post by delslo »
kleancut;191305 wrote:notorious problemo. karate chop that mutha, and get a new bolt.
I def cut it out with an angle grinder, Do work son!
kleancut
Post by kleancut »
most turner shops have these bolts in stock due to this problem
I love Portishead.
bemberg2
Post by bemberg2 »
i've tried everything besides cutting it out. anyone have any good shops where i could get this done? or is someone willing to cut it out for a case or cold ones?
