new fuel pump new relay still wont start
gcef89
so i got a walbro fuel pump and a brand new relay but my car still wont start i'm thinking maybe my injectors aren't getting power how can i test this or could my fuel lines be filled with crap?
does your fuel pump turn on?
do you have fuel pressure?
how old is your fuel filter?
does the car get spark?
do you even know if you have a fuel problem or is it an electrical problem?
what kind of car is it?
what is the issue?
what have you checked and tried?
does your car not start since you replaced the relay and fuel pump but did before?
what is the issue?
Told you not to buy that damn thing just yet.
gcef89
fuel pump turns onrickles8099;269751 wrote:does your fuel pump turn on?
what is the issue?
fuel filter is new
im not sure if the car is getting spark
i'm pretty sure i'm getting power tested all wires but not getting any fuel to fuel rail
car is a 91 civic si with b18a1
issue no fuel
checked wires fuses all good and fuel lines= no fuel
car did not start b4 new fuel pump and relay i had a bad relay b4 so decided to change fuel pump and relay since ill be going turbo later
gcef89
lol oh well its progress to my turbo later im usually pretty good at figuring things out but this has got me lost!Phate;269767 wrote:Told you not to buy that damn thing just yet.
does it have fuel in the tank?
check your grounds, particularly the one by the back hatch, just under the latch (very back of the car in the middle between the tail lights) its got a few grounds going there, including the one for the fuel pump. i know you said the pumps runs, but it could be intermittent or not have a good ground or a solid 12v going to it. you could also check the voltage/ground at the plug under the back seat.
gcef89
i might need more fuel? tank was empty put two gallons in it thinking it would start so i could make it down the road to the gas station do u think i need more gas?
put more in, cant hurt.gcef89;269773 wrote:i might need more fuel? tank was empty put two gallons in it thinking it would start so i could make it down the road to the gas station do u think i need more gas?
gcef89
seems to me i have no fuel pressure my gas pedal doesnt seem right!
your gas pedal doesnt directly affect anything that would cause that
Racecore.com
Racecore.com
