Some one help? po6 ecu on h22a?
1.6 crx si
Post by 1.6 crx si »
I have a h22a eg but the vtec seems to not be working. It's just a very mellow increase in rpm..no crossover what-so-ever. So first thing I did was check over the wiring and it seems to be correct with good connections. I worked my way down to the ecu and noticed it was a po6 ecu.. for a civic 1.5 non vtec...I assume this would be my problem correct?
The other thing is I popped the ecu open and it has a "demon" chip inside? No nothing about it, or if that should make the po6 acceptable. If anyone heard of this ecu working for a h22a then I suppose i'll look into it being the sillinoid?
Someone please help or atleast give your opinion.
Thanks
A P06 can be converted to a p28 and run a h22 with vtec with no issues. A couple people on here could burn you a acceptable base map. If you are still having issues with the ecu after that hook a volt meter up to the ecu pin and have a friend watch while driving.
Post by Phate »
Who did the swap? You should talk to them.
1.6 crx si
Phate;262738 wrote:Who did the swap? You should talk to them.
Not a good idea..The swap was done very well. Looks good, no hoopty wires every where, and seems to be wired correct. So im not even sure the guy I bought it from did the swap like he said. My reason for saying this is because when i texted him "why cant i hear crossover"? His reply was "you cant hear crossover with aftermarket exhaust"....Soooo, that was the end of asking him.
1.6 crx si
Waffles;262737 wrote:A P06 can be converted to a p28 and run a h22 with vtec with no issues. A couple people on here could burn you a acceptable base map. If you are still having issues with the ecu after that hook a volt meter up to the ecu pin and have a friend watch while driving.
I will have access to a p13 tomorrow. If I throw that ecu in and I have vtec does that mean the po6 was chipped wrong or something? sorry for lack of knowledge.
Redline
Post by Redline »
is it a white eg hatch with h22 swap, it so i know who did the swap
More power coming soon
1.6 crx si
Redline;262758 wrote:is it a white eg hatch with h22 swap, it so i know who did the swap
Nope its a dark grey eg
Fzn14
Post by Fzn14 »
Thats me :multi: lol
crxfornow
Post by crxfornow »
run the p13 then tell us what is going on
