wrong!91beatuphatch;247650 wrote:umm i dont think youd even have oil pressure running that high of a rev. if im not mistaken they start dropping oil pressure at like 8200.
its a b16, not really an issue.Dark_CB7;247678 wrote:Doesn't crome's launch control cut fuel only? Using that is a terrible idea.
Also, why has no one even mentioned piston speed and rod ratio about revving to 11k!????
bottom line is, he has no buisness reving it that high. if its a stock valvetrain then hes floating the piss out of the valves and is going to break a spring,valve,etc then hes going to need alot more than upgrades.
i should have just multi quoted, but nonetheless, start a new basemap and transfer the numbers and info to the new one. it will work again.2ksi;247676 wrote:i cant remember at the moment. i will check tomorrow. all the numbers are on a laptop at a friends house. cant get them right now. i will update the thread around noon.
ill say again, you are going to destroy what u have.
