Need help all motor d16 wont warm up
mlr198769er
OK here's the deal. I got a mini me d16y7, d15b head that been milled, jg adjustable cam gear @6 degrees advanced, a1 pistons, lightweight underdrive pulley, 7lb flywheel, new rods, bearings, rings, no a/c or p/s. Everything combined ended up with 270-260-265-260 psi compression. Its in a ek, stock radiator and thermostat. Will not warm up. Changed the thermostat and sensor. The gauge works cause if I run it low(when im flushing it out) it will warm up. Fill her back up and she cools back down and wont warm up, EVER. Blows out hot air from the vents when the heater is on but not scorching hot or anything. IDK. Im out of ideas and i've been looking for answers everywhere noone can figure it out(so far). Runs on 93 octane and runs really strong. One guy said its just to much compression and another said its the fuel cooling it down. Any help and ideas will be tried thanks. Im running the stock p2p ecu could this be a problem? The reason i say this is because i dropped the car into a hatch originally and it warmed up for a little bit but when i would drive down the road it would do the same thing temp would drop and wouldnt go back up
Thermostat stuck open.... Or missing.
mlr198769er
no put another new thermostat in it and it's definately in there lol. Tried getting a hotter/colder one but the parts stores are gay and say i can only get a stock one and that they cant get a different one
OK, second option is the "loop hose" that goes from the passenger side of the intake to by the thermostat housing is in the wrong spot. That will let water bypass the thermostat all the time and have the car run cool.
mlr198769er
wait what other hose can that be mixed up with... a heater core hose or what
mlr198769er
ok so i pulled the car into the garage and i checked the hose and heater core hoses and compared it to this pic
http://img268.imageshack.us/img268/2767 ... outing.jpg
mine looked exactly like this.
mlr198769er
omg i've had this car 3 months now and i think i just figured it out with a bit of your help imma go take it out for a test drive. The heater cable came of that valve on the firewall and was letting all the water bypass the termostat. Hang on i'll post up in five or ten minutes
mlr198769er
ha ha nope didnt help. Thought maybe my luck had changed there for a sec and karma b**** smacked me in the face again
mlr198769er
anyone ever heard of the dash gauge going outta sync? or need to be recalibrated? Cause my awesome instincts for picking up a cool ass laser thermometer paid off and is telling me that my thermostat housing is 159 on the hot side and 140 on the cold side
CHECK
THE
LOOP
HOSE
160 is too cold. #3 in this pic. Make sure it's hooked up as shown. If not, like I said, that's your problem...
http://www.hondaautomotiveparts.com/aut ... VTEC)+(MT)
THE
LOOP
HOSE
