gears
gears
you would have to get the correct ecu and either wire up vtec or buy a harness from a vtec car(ex, si, or hx) make sure to get an obd2a ecu if your car is 96-98 or an obd2b ecu for 99-00. same goes for the harness. they have to match
Racecore.com
Racecore.com
v-tecivic
gears
also with that, the secondary O2 sensor is apart of the ex cabin harness. to get by that you'll just need to run an extension harness from the ecu to an O2 sensor after the catalytic converter.HardCore97;225838 wrote:you would have to get the correct ecu and either wire up vtec or buy a harness from a vtec car(ex, si, or hx) make sure to get an obd2a ecu if your car is 96-98 or an obd2b ecu for 99-00. same goes for the harness. they have to match
97 civic ex turbo
13.1@112
