Just curious how much heavier the pedal is over stock? I think I'm going to go with the ACT Extreme pressure plate, Performance Street disc, and a StreetLite flywheel in the coupe. If the pedal is WAY stiffer than stock, I may just stick with stock ITR.
Ryan
Anyone here use an ACT Extreme PP on B series Hydro?
integ2000ls
I am running the extreme in my teg with the streetlight flywheel. It has a stiffness to it but it feels good, not TOO stiff.
Good deal. That's what I plan on putting in the silver coupe. That PP with the performance street disk puts the torque handling capability at 319. Should be more than I EVER throw at it...
Wonder how that is on throw out bearings...
Digital Sol
i heard that the xtreme pp was very harsh', and isnt that rated to like 409ft/lbs of torque?
i just got mine today but i went with the heavy duty pp and spring 6 puck + streetlight flywheel...rated to 311 ft/lbs of torque', ill let ya know how it feels
integ2000ls
Thi kit I picked up is rated at like 487 ft/lbs. I have the 6 puck sprung with the extreme I believe. Id have to look at the box again. But i know it was rated at like 487.
Digital Sol
what kind of motor mounts are you usuing?integ2000ls;156317 wrote:Thi kit I picked up is rated at like 487 ft/lbs. I have the 6 puck sprung with the extreme I believe. Id have to look at the box again. But i know it was rated at like 487.
id imagine that would be very....very harsh on the tranny mount
unless your making 500+whp id imagine that is alot of overkill
integ2000ls
The tranny mount is an Solid mount. and the rest have the energy inserts for now, wanting to upgrade them in a bit. I picked the clutch that would work best for my engine set up :msnwink:Digital Sol;156319 wrote:what kind of motor mounts are you usuing?
Digital Sol
nice...thats all i needed to hear'integ2000ls;156404 wrote:The tranny mount is an Solid mount. and the rest have the energy inserts for now, wanting to upgrade them in a bit. I picked the clutch that would work best for my engine set up :msnwink:
integ2000ls
lol, yup yup
all i can say is ACT sucks.
