Hydro or cable transmission???
B16aRS
Post by B16aRS »
I have another question, i have a B16a with a LS tranny. I want a new tranny so i can have some acceleration. Would i be able to tell much difference between a GSR tranny and a B16 tranny? If so in which gear. I already looked at the gear specs but none of it makes much sense to me.
kra95civic
Post by kra95civic »
b16 tranny has shorter gears for better acceleration
b18 tranny has gears just like an ls but different in some way not sure
this would be a good time for rick to jump in here
getteg
Post by getteg »
I would assume the B16 trannies gears are closser because of the lower displacement and HP. With the gears closser it gives you better accelaration over the B series trannies longer gears.
I also believe if I remember right that the LS and GSR's trannies have the same gearing 1st-3rd
Remember though I am not a tranny specialist.
Post by RyanA »
I'd type everything but this is easier:
http://www.superhonda.com/forum/f5/b-se ... es-218900/
