Timing Belt
iStick
Timing Belt
Lastnite I bought a new timing belt and put it on my 93 Prelude Si 2.3L when testing it out before putting the water pump and altenator belt back on my car was idiling really high and then after the 1st iginiton try it wouldnt start the same... What could be wrong? I was thinking maybe the timing is off by a hair and needs to be adjusted? Any suggestions?
93Ludetta
follow me on twitter @ScanMyBCode
:honda:
:honda:
Timing Belt
You probably didn't install the belt correctly, and now your engine is out of time.
iStick
Timing Belt
So basically all I need to do is re-time the belt?
93Ludetta
:honda:
:honda:
Timing Belt
Make sure your mechanical timing is on first. Get the engine to TDC, check the timing marks on your crank pulley, and on the cam gears.iStick;270760 wrote:So basically all I need to do is re-time the belt?
iStick
ymisoqt
Timing Belt
And make sure you rotate the motor by hand using the crank pulley and that all of your timing marks are still lined up after doing so.
94 Legend
94 Del Slo
90 S13 <3
iStick
Timing Belt
There is no mark on the crank pulley??? If so anybody got a pic so I can see what it looks like??
93Ludetta
:honda:
:honda:
Boosted_da
Timing Belt
there is a key way on the crank snout
iStick
fry
Timing Belt
O lord. Hope you didn't lose the crank key.iStick;270803 wrote:Whats that?
