Electrical BS
92_luder
Electrical BS
Post by 92_luder »
So my passenger side headlights arent working....high or low.....driver works fine...........the passenger side fuse is fine......but im not gettin power to my hid ballasts at all.......what could i b missing?
Electrical BS
an E
92_luder
Electrical BS
Post by 92_luder »
Waffles;265407 wrote:an E
real cute, thanks bro....
STLWagovan
Electrical BS
Post by STLWagovan »
I assume ( since i dont know who you are, and you neglected to say what you have) that you have an aftermarket HID kit on your 92 prelude?
If you have not power getting to the ballast, trace the wire to find the break in the line?
Also check your grounds.
I assume you are checking the "power" line with a multimeter ( DMM - digital multi meter) - what voltage are you seeing?
92_luder
Electrical BS
Post by 92_luder »
STLWagovan;265429 wrote:I assume ( since i dont know who you are, and you neglected to say what you have) that you have an aftermarket HID kit on your 92 prelude?
i was checkin with a test light...and i thought about it being a break in the wire but does that jus happen....shouldnt there b symptoms for a breakin wire......dim light, sometimes not coming on and other times theyre fine....?
Fzn14
Electrical BS
Post by Fzn14 »
I would buy a meter and actually see what the voltage is there if any...not to mention it will tell you if you have a good ground going threw the system or not. Even though the fuse looks good, that isnt always thew case.
92_luder
Electrical BS
Post by 92_luder »
Fzn14;265442 wrote:I would buy a meter and actually see what the voltage is there if any...not to mention it will tell you if you have a good ground going threw the system or not. Even though the fuse looks good, that isnt always thew case.
thanks
STLWagovan
Electrical BS
You didnt answer my question tho..
1) Is this an aftermarket system?
2) Where is the fuse located?
3) How long have you had this system in the car?
I would check the ground for the ballast / bulb.
(To Test with a Test Light) Put your test light on the positive side of the battery, then test the ground spot. It should light up if the ground is good.
92_luder
Electrical BS
Post by 92_luder »
i found the short thanks for those of you who helped.
problem solved !!!:occasion18:
