hey guyzz....
sooo ...last night i was driving down 55 when out of no where i blew a rod....well im pretty sure i blew a rod. i plan on fixing this my self. so i was hoping on some help on the things i will need to replace the rod went threw the oil pan. so of course i need to replace that.but is there a way i can just replace the block without changing the whole motor.
pls help......
last night..
last night..
the block is kind of most of the motor. to do it properly though, youll need to pull the engine. take off the head and oil pan. remove the piston and rod and inspect the cyclinder walls, all of your bearings, oil pump, and head for damage from rod parts. if and only if there is no damage to anything, you can replace the rod. if there is damage to anything, they will need to be replaced and youll need to clean everything throughly to get all the metal shards out of everywhere.
or you replace the motor with a known good one and be on your way.
low_ej1
last night..
ok so i might as well just replace the whole motor instead of wasting my time.is what your saying.
rickles8099;289813 wrote:the block is kind of most of the motor. to do it properly though, youll need to pull the engine. take off the head and oil pan. remove the piston and rod and inspect the cyclinder walls, all of your bearings, oil pump, and head for damage from rod parts. if and only if there is no damage to anything, you can replace the rod. if there is damage to anything, they will need to be replaced and youll need to clean everything throughly to get all the metal shards out of everywhere.
muha22752
last night..
Yap, it will definitely be easier than anything else.
umadbro?
"You have to pay to play"
W.K.D
1995 Civic Si 1.6 (Sold)
2003 Audi A4 1.8t (sold)
W.K.D
JDM EM1
last night..
Depending if u have a vtec head, and are wanting to keep same motor u could pull the head, inspect it, and throw it on a new block or sell it.
ymisoqt
last night..
Just replacing the block might be the most cost effective if you can put the motor together yourself. That's what I did when I spun bearings. Of course, like already mentioned in your case you need to check the head for damage.
94 Legend
94 Del Slo
90 S13 <3
VTEC95EG2
last night..
k, im not saying that you dont know anything about cars nor am I saying that I know a lot... but by the way you asked, my advice to you would be to jst find an engine and replace it...if you're not really experienced on working on bottom ends this will save you a lot of headaches and possibly money in the long run.
"I am careful not to confuse excellence with perfection. Excellence, I can reach for; perfection is God's business."
1995 DelSol Vtec:vtec228:
1998 DxHatch (sold)
1988 Crx Si (sold)
2001 Yamaha R6 (sold)
1998 DxHatch (sold)
1988 Crx Si (sold)
