Here is what he told me about the car and maybe some of you are familiar with the car. It was built in a Ranken class:
1996 Honda Civic EX D16Y8
Engine info- 2,200 miles on build
Stage 2 turbo grind crower cam: Duration: 312deg. intake: 318deg. exhaust with I/E .430/.427 lift
Supertech valve springs (single spring) with titanium retainers
machined block bored .020" or 2.972" bore diameter with main girdle alignbored to specs. (engine was hot tanked)
decked cylinder head and balanced crank
wiseco forged aluminum pistons 8.5:1 compression
Eagle H-beam rods with acl race rod and main bearings
Garrett 60-1 journal bearing turbo
SX performance fuel pressure regulator with Walbro 255lph pump, and RC 550cc injectors (pumping 1 lpm with setup)
apexi v-afc tuner with a (safe tune) running 12-14psi boost
Tial 38mm wastegate with 18lbs. springs
I realize there is more info needed (tranny, clutch etup etc...). The only weak point in the setup is the VAFC in my mind so that would be something I will play with if all goes well. Here are my concerns:
1. Besides tranny, clutch, and axel potential issues what weak points might be in this setup?
2. What kind of power do you think this car run as a street car (driven a few times a month)?
3. Any other info, opinions, or advice is appreciated.
