crankshaft
91TEGDA
crankshaft
the gear was seized on so my teacher with 20 years experience took a blow torch and lightly applied heat then we took a gear puller and pulled it off. nothing was glowing
crankshaft
Is there still a big hoop on the back(flywheel side) of the block that was around the end of the crank?
Focke
crankshaft
Yea, some reason sounds like a man is or was still on.
crankshaft
Thats what I am thinking too. A crank should lift strait up. If its getting hung up on the timing gear that means they are lifting from one side.Focke;273812 wrote:Yea, some reason sounds like a man is or was still on.
91TEGDA
crankshaft
yeah the front main seal was still on, couldnt get the gear off, buts its all good now no damage was done
Focke
crankshaft
HA!!!!! I was right!!!91TEGDA;273823 wrote:yeah the front main seal was still on, couldnt get the gear off, buts its all good now no damage was done
