crankshaft
91TEGDA
crankshaft
Post by 91TEGDA »
the gear was seized on so my teacher with 20 years experience took a blow torch and lightly applied heat then we took a gear puller and pulled it off. nothing was glowing
crankshaft
Is there still a big hoop on the back(flywheel side) of the block that was around the end of the crank?
Focke
crankshaft
Post by Focke »
Yea, some reason sounds like a man is or was still on.
crankshaft
Focke;273812 wrote:Yea, some reason sounds like a man is or was still on.
Thats what I am thinking too. A crank should lift strait up. If its getting hung up on the timing gear that means they are lifting from one side.
91TEGDA
crankshaft
Post by 91TEGDA »
yeah the front main seal was still on, couldnt get the gear off, buts its all good now no damage was done
Focke
crankshaft
Post by Focke »
91TEGDA;273823 wrote:yeah the front main seal was still on, couldnt get the gear off, buts its all good now no damage was done
HA!!!!! I was right!!!
