d16y8 help. wont crank or start at all
1389evo
just bought a 99 civic ex, i just put a new battery in it, and checked all the fuses. the car wont even turn over at all..
hellasubtle
1389evo
it clicks, but wont even turn over i even tried hitting the starter too
hellasubtle
so starter wont turn? check engine light? does it go out? on solid? fuel pump priming? main relay clicking? main harness ground attached and tight?
91beatuphatch
id say check for corrosion on the battery terminals, check wires to the starter, also voltage test the starter if possible. do the easy stuff first.
eh2_Erik
the dude told you the motor locked up on it, i bet the oil was never changed and the damn thing seized from sludge.
Now s13_Erik
1389evo
just put a brand new oem honda battery in,disconnected and re connected the starter wires, tried putting a 17mm on the crank pulley and it wouldnt even move91beatuphatch;266475 wrote:id say check for corrosion on the battery terminals, check wires to the starter, also voltage test the starter if possible. do the easy stuff first.
hellasubtle
1389evo
but there is always a chance maybe it could have been something simple. so now im on a search for a legit d16y8eh2_Erik;266477 wrote:the dude told you the motor locked up on it, i bet the oil was never changed and the damn thing seized from sludge.
hellasubtle
1389evo
i put a 3/8 on there and stood on the darn thing and it wouldnt go any where, plus tried to pop start it and it just fell on its face and locked upWaffles;266507 wrote:Can you put a wrench on the crank and turn it by hand?
hellasubtle
