15b7 with y8 head...
i pulled the lil oil valve out of the block before bolting on the head...
now it just shoots oil in the cylinder any idea as to were i went wrong? maybe bad rings?
block was rebuilt by Dale, he built it a while ago for another member on the board, i bought it from him... never run till now...
b7/y8 MiniMe - oil getting into cylinders, did i miss something??????
4Door
H.E.A.R.T
Could be a flipped piston ring, or if all the gaps are lined up on the piston rings it could do the same.
Yeah the oil control ring could be upside down.
4Door
can the piston be removed and checked/rings fixed with out removing the motor..?
just pull the head, exhaust, oil pan..?
thank you for the quick replys...
H.E.A.R.T
Yep. Ive done 2 rebuilds like that.4Door;257657 wrote:can the piston be removed and checked/rings fixed with out removing the motor..?
tommygun89hb
is there standing oil in the cyn???
If so then i dont think its your piston
some simple things to check first
Is the Head gasket installed right as in Did the head gasket say up when you put it on.
and to answer your question on the piston check yes and no
you may not be able to see if a piston ring is flipped like waffles said.
oil control rings are the same and can go on in either way. the compression rings on most go on one way. these b7 rings are not like the b-rings.Phate;257639 wrote:Yeah the oil control ring could be upside down.
this block was built damn near a year ago and has been sitting until now. rings can be stuck because of it. dont know.
4Door
ya, i was told the motor sat for about a year... could a ring break from sitting and then starting..? i'm almost positive its the cylinder 2nd from the dizzy (3), i'll pull the piston and see if i can tell if a ring is broke or simply not clocked...Gunmetal Si;257671 wrote:oil control rings are the same and can go on in either way. the compression rings on most go on one way. these b7 rings are not like the b-rings.
this block was built damn near a year ago and has been sitting until now. rings can be stuck because of it. don't know.
again, thank you for the suggestions...
H.E.A.R.T
4Door
picked up a set of B7 rings today, hope to be able to have it done by the weekend...
H.E.A.R.T
4Door
i pulled the #3 piston last friday, the rings looked fine aside from not being clocked, the gaps were lined up perfectly with each other so i clocked them them and re-installed it... it still smokes pretty bad but not as much as it was... I'm not sure if it's due to residual oil in the exhaust port/header or what, it sucks tho...
do i need to just let it run? maybe the oil that's left in there needs to be burned out?
[ame="http://www.youtube.com/watch?v=DBJS2wnFVG0"]YouTube - 92 Civic, smokes[/ame]
H.E.A.R.T
