Hmm....b18a1 w/ Boost Or b18a1 ls/vtec w/ Boost?
stlhonda92
Post by stlhonda92 »
Looking For Suggestions Should I Go With The Ls/Vtec Swap And Boost It Or Stick With The Stock B18A1 Head And Have It Tricked Out Since Heard The Vtec Doesnt Really Matter When You Get Into Forged Induction....
boosted hatch
Post by boosted hatch »
whoever told u that is a dumb ass.if you gonna chose between those 2 motor i go with the ls v.
sharpie
Post by sharpie »
Vtec heads flow a lot better even if the ls head is ported they still aren't as good as a vtec head
Boosted_da
Post by Boosted_da »
wow never heard of forged induction and it all depends on what your plans are if i were you id build the bottom end first you can always add a vtec head later
Uncle_Willie
Post by Uncle_Willie »
I used to own an LS and i was very against Ls-vtec. Then i bought an Ls-vtec and im sold on them. It makes a huge difference. Start looking into built turbo'd Lsv's....theyre sick. Just make sure if you go that route, you have it done by a reputable shop. Ls-vtec can be unreliable if not done correctly. And a tune makes a huge difference too:thumbsup:
1992 Civic Dx Sedan
l D15B Vtec l Tucked l lowered l Fit Sport Wheels
Post by rickles8099 »
stock bottom end can handle the same.... about 300whp. sure they can handle more, but reliably, 300whp is about the limit. you can get 300whp on a stock ls or ls-vtec. so if youre planning on keeping a stock bottom end, i say stay with stock ls. if youre gonna build bottom, go ahead and add the vtec.
stlhonda92
ok thanks everyone ..yah im keeping stock sleeves but getting crower rods and JE Pistons ...and think i may just boost it with stock head for now and have vtec head done up later ...whats a good reputable shop for doing the ls/vtec head work or swap?
Post by 5thgen »
stlhonda92;254963 wrote:ok thanks everyone ..yah im keeping stock sleeves but getting crower rods and JE Pistons ...and think i may just boost it with stock head for now and have vtec head done up later ...whats a good reputable shop for doing the ls/vtec head work or swap?
Are you doing any of the work yourself?
It isn't too bad. You will need a conversion "kit" that contains everything.
headgasket
oil line to head
fitting into head for feed oil
tap and plug for an oil pressure galley
adapter for oil feed to pressure source
and gsr everything else (water pump/headstuds/timing belt etc.)
and any obd2 oil pump
......at least thats what I have I think.
5thgen;254974 wrote:Are you doing any of the work yourself?
headgasket
oil line to head
like he said... a kit like this:
http://www.xenocron.com/vtec-conversion ... p-268.html
Boosted_da
dont forget to tap and plug the bottom of the head or you will have a oil leak from hell
