Hello, I had a leak in the intake manifold gasket on my hatch, so I removed everything, needed cleaned anyway. Since I have the TB off, I cleaned it like new(no more sticky throttle). Also going to clean the intake like new and paint it black, I'll post pics when it's done:)
I don't want to grind the old gasket off, so I was wondering if the gasket remover spray at Autozone help to soften up the old gasket? It is on there like cement!
Thanks, Chad
Cleaned the TB and IM, can't get gasket off!!!
lagwagon21
2008 Fit Sport(wifes car), Vivid Pearl Blue, 5 speed, completely stock 1.5 VTEC, tinted windows, Rota Ciruit 8 16" wheels(Bronze), Thule rooftop bike carrier.
Yeah use a gasket scraper (razor blade). Just takes some elbow grease.
lagwagon21
Ok, I scraped it for about an hour last night. Then I said there has to be a better way! Guess not. WD40 did help soften it a bit though.
CmeltoN
Use some lacquer thinner...it'll eat it right off there...
lagwagon21
Thanks!
Bristle disk on a die grinder will take it right off.
lagwagon21
Did all the above! Just a little more to go on the block then it will all be off! There are some little scratches on the manifold. What should I finish sand it with?
? are they like deep or what, you shouldn't need to sand itlagwagon21;253373 wrote:Did all the above! Just a little more to go on the block then it will all be off! There are some little scratches on the manifold. What should I finish sand it with?
lagwagon21
There are a couple deeper nicks on the manifold. Not too bad though. I got her all cleaned up.
CmeltoN
You can use some emery cloth to finish sand it...
