b18 swap questions
OWNED
b18 swap questions
Post by OWNED »
ok, ive done some research but im still a little confused on the wiring. im swapping a obd1 b18b1 into my 99 civic hatchback. the car currently doesnt have a wiring harness so my question is: should i pick up a wiring harness for a 99 civic hatch or a harness for the b18? and is there any differences in the wiring harnesses between the civic hatchback/coupe/4door? and will i need any conversion harness for the wiring harness since the motor is obd1 and my car is obd2?
the car also doesnt have an ecu, i believe i want to get a p72 for my swap. is this correct?
-Shane
(1999 Civic Hatchback)
b18 swap questions
Post by Gunmetal Si »
why dont it have a harness. u need to have a obd2b harness. gsr ecu will only work if u socket and chip it and burn map for the ls.
OWNED
b18 swap questions
Post by OWNED »
Gunmetal Si;253237 wrote:why dont it have a harness. u need to have a obd2b harness. gsr ecu will only work if u socket and chip it and burn map for the ls.
i bought the car as a shell so its literally "a shell" lol. so i need to find a harness out of another 99 civic hatchback your saying? and i should get the p06 ecu instead of a p72? i was planning on sending out whatever ecu i get to be reflashed anyways.
-Shane
b18 swap questions
who u get the shell from
OWNED
b18 swap questions
Post by OWNED »
crazysol. its 99blackhatch's old car
-Shane
b18 swap questions
You should be able to figure almost everything out from this. The correct ECU to use is a P75. If you use an OBD1 ECU, you'll need an OBD2B-OBD1 conversion harness.
b18 swap questions
actually its myold hatch. i know more about that car than anyone including blackhatch i i striped that car and completey wire and brake tucked it!
OWNED
b18 swap questions
Post by OWNED »
JustRob;253263 wrote:You should be able to figure almost everything out from this. The correct ECU to use is a P75. If you use an OBD1 ECU, you'll need an OBD2B-OBD1 conversion harness.
awesome! thank you soo much for that info! very helpful!
-Shane
OWNED
b18 swap questions
Post by OWNED »
Gunmetal Si;253273 wrote:actually its myold hatch. i know more about that car than anyone including blackhatch i i striped that car and completey wire and brake tucked it!
oh wow, thats cool. well ill prolly pm with some questions here soon man. if thats alright?
-Shane
MasterTech95
b18 swap questions
Post by MasterTech95 »
i think im running into the same type of problems with my 96 gsr>>>i put a non vtec b18b1 motor in it with a hydro lsd trans and i got a b18b1 ecu but i cant get the fuel injectors to fire properly.... any info?
