ok looking to get a d16z6 instead of fixing d16a1.
i no i need a p28 ecu but will that plug in?
and what would i need to do as far as wiring
can someone post up the parts list were i could drop it in and start driving
d16z6
crx08
CRX91
d16z6
what would be the best way to do this i would like to get the car up and running in a weekend if posible. i looked rywire.com it said u had to send in your new and old harness i need my car for work. is there a shop that can do this around here?
onecam12sec
d16z6
You could chip your current ecu for vtech, and then run the necessary vtech wires to it form the solenoid.or you'll need a jumper harness for your dizzy and one for your ecu. Obd0-obd1 jumpers from rywire and just use the stock z6 ecu. Just my 2 cents
d16z6
first off its VTEC not VTECH, second unless the current ecu is a ps9 or an obd1 p06 you cant "chip it for vtec".onecam12sec;233396 wrote:You could chip your current ecu for vtech, and then run the necessary vtech wires to it form the solenoid.or you'll need a jumper harness for your dizzy and one for your ecu. Obd0-obd1 jumpers from rywire and just use the stock z6 ecu. Just my 2 cents
you would need a d16z6 distributor, 4 wire o2, obd0-obd1 jumper harness and a p28 ecu to convert to obd1 you can repin obd0 distributor plugs on to the obd1 distributor so you dont have to get a jumper for the distributor.
