firewall motor mount? replaced and motor still bangs and rocks
00tegLS
i had my fire wall mount replaced and it took them a day and half to do it. they were having problems geting the center bolt to line up.. well they finally got it done and the motor still rocks back in forth and when u get on it and shift from first to second the motor just bangs still. all other mounts were replaced as well. so wtf is going on here??? cant see if they tore the mount puttin it in because of bracket around the mount..what to do now?
gsrauto98
Where did you take the car? Sounds like they are complete morons. Have you checked over it? as in bolts are tight and what not. Just get a hasport mount and call it a day.
00tegLS
auto tire on mexico
Lol, spending money on parts isnt going to solve a unknown problem. He clearly needs to find out what the actual problem is, versus spending money to "get a hasport mount and call it a day"Chewbacca;226664 wrote:Where did you take the car? Sounds like they are complete morons. Have you checked over it? as in bolts are tight and what not. Just get a hasport mount and call it a day.
gsrauto98
well he said the mount looked ripped up.....Phate;226667 wrote:Lol, spending money on parts isnt going to solve a unknown problem. He clearly needs to find out what the actual problem is, versus spending money to "get a hasport mount and call it a day"
No, he didnt.Chewbacca;226668 wrote:well he said the mount looked ripped up.....
Where do you live OP? You should come out to bubbletea thursday or something, and we can look at it.00tegLS;226663 wrote:i. all other mounts were replaced as well. so wtf is going on here??? cant see if they tore the mount puttin it in because of bracket around the mount..what to do now?
gsrauto98
IDK what the fuck i was reading...carry on lolPhate;226670 wrote:No, he didnt.
it's the torque mounts most likely they are the main ones that ALWAYS go bad on hondas and even faster on automatics. They are located under the frame rails at the front of the motor on each side of the ebay, they are attached to the brackets that come off the transmission and ac brackets
here is a write up on how to fix them , and just to give you a better idea of what they are and where on the car .. and they are ALL in the same place for integra and civic
http://importnut.net/motormount.htm
00tegLS
ya i replaced those mounts also. they all have been replaced..
99BlackHatch
Your Honda is just making too much power... shut up and be happy with that "reason" alone.
SquadronOne.net
SquadronOne.net
