Need suggestions my motor is going out
da9teg
Okay so i'm driving to get on the highway when all of a sudden the car starts missing. It continousily misses while driving. I took it to the shop and they said my valves in cylinder 4 are not opening and theres no compression in that cylinder. They said labor alone is around 800, with parts maybe 1400 (that includes removing the head). Does anyone know a way around doing all this work? I don't really want to spend that much on this motor and if i sell the car i don't know if i will have enough to get a new one. Does anyone have any ideas? And also does anyone know where i can find a parts list to do a b16 swap in a 91 auto integra?
google can find a parts list for that swap. as for the valves, i would say do it yourself if you know how
Racecore.com
Racecore.com
red dragon
There is a d16y8 on craigslist in st louis for $400 bucks says it runs perfect theres also a full ls swap on there for $650 says he has everything needed for a full swap if it were me i would find another longblock and swap it out myself instead of pay a shop $100 an hour to try and fix mine .02 werth good luck.
1994 CIVIC SI HATCH STAGE2 VENOM INTAKE,62MM TB,CAI,VTEC COTROLLER, HEADER,2.25 EXAUST,NGK PLUGS,8MM WIRES,AC AND PS DELETE TO BE INSTALLED CROWER STAGE 2 CAM CRANK UNDERDRIVE PULLY
i would take the head off and see if there is damage to the pistons. if no damage to pistons, throw on a different head (can be had for $50 or sometimes cheaper since your screenname is da9teg im guessing we are talking about a ls motor cuase it was not stated what you have in your original post) with a new water pump and timing belt and then call it a day.
red dragon
Yeah.... im retarded :dumb:scratch that i dont know why i was thinking you had a d16 but there is a ls longblock on craigslist if your motor is done.red dragon;204803 wrote:There is a d16y8 on craigslist in st louis for $400 bucks says it runs perfect theres also a full ls swap on there for $650 says he has everything needed for a full swap if it were me i would find another longblock and swap it out myself instead of pay a shop $100 an hour to try and fix mine .02 werth good luck.
da9teg
yes it is a 91 ls. i may end up taking the head off this weekend. is it complicated to do? if my pistons are ok and my valve is truly stuck how can i get it unstuck and are there any special tools i may need besides a torque wrench?
