oil problem
J.M.P
oil problem
Post by J.M.P »
Blueguy0123;199719 wrote:On step 4. crank the starter 3-4 rotations
Yea i read that somewhere.
oil problem
cyclohonda;199715 wrote:right I did that, but then turned it off, didnt know to leave it on
You want to have the car at operating temp(but off) when you start on step 1
J.M.P
oil problem
Post by J.M.P »
so let it warm up, then turn off, and pull the fuel pump fues, then start it up again?
edit: nvm, I got it now, thanks
btlfed7;199723 wrote:You want to have the car at operating temp(but off) when you start on step 1
oil problem
Post by bildo16 »
more than likely you didnt fuck up anything seriously, if you were to just go out and drive the car, it will probably stop smoking.
J.M.P
oil problem
Post by J.M.P »
OK, I did everything on the list, or so I thought I did. I looked up which fuse was the fuel pump fuse, and there isnt a direct fuse, right? From what I looked up, it said #18 was the fuel pump fuse, but that doesnt seem right, and there wasnt a direct answer to which one would relay back to the fuel pump. Can anyone confirm which one it is? Also I drove it around the block, it still smoked, then i let it sit, and now it barely puffs out, its white smoke though. just updating here. Thanks
Blueguy0123
oil problem
Post by Blueguy0123 »
cyclohonda;199903 wrote:. I looked up which fuse was the fuel pump fuse, and there isnt a direct fuse, right? From what I looked up, it said #18 was the fuel pump fuse, but that doesnt seem right, and there wasnt a direct answer to which one would relay back to the fuel pump.
Just pull the one you think it is and try to start the car. if it keeps runnin for a couple of mins then it aint the right fuse. Your not gonna hurt anything so dont worry
