What to do with a GSR
Nitrous does not cause an engine to blow up, idiots using nitrous cause engines to blow up. If a "kit" is installed correctly and tuned correctly you can run nitrous all day long and cause no more harm that a turbo at the same power gains.
Post by bildo16 »
go find a used JRSC kit, you can find them for 1200-1500. this will put you close to the numbers you want.
Post by Gunmetal Si »
lafff at this. ask question, get the correct answer, you dont like it. nice!!!!!!!!!!!
CourtesyFlush
Post by CourtesyFlush »
so with the nitrous or JRSC ima need a Hondata......which is like 1400 bucks correct?
95acuraintegra;191517 wrote:so with the nitrous or JRSC ima need a Hondata......which is like 1400 bucks correct?
incorrect.
tmarsh
Post by tmarsh »
naw man, you're right. keep it up with them budget bolt ons and maybe one day you'll be faster than my grand am. magazine racing rawks.
'98 Grand Am: Wider is Better!
dcdorthydriver
Post by dcdorthydriver »
You need to do alot more Logical Research before you just start tearing stuff apart and spending money on it. But hey, its your car and your money. Everyone here is trying to answer YOUR question, with what they/we think would be a logical choice for what you're asking. If you dont like the answers than move on.
No offense, but you are probably new to all this.....as stated by your PnP making a HUUUUUGEEE difference statement. Take advice, learn yourself a thing or twelve. Do some research....then come back and ask questions.
Im not trying to be a dick, I myself....am just trying to help you out. Just like (almost)everyone here.
Listen to whats been said so far...... All of what you have in your head are supporting mods. By themselves they do practically nothing. A combination of them.....done right....can/will give you some perfomance increases. Dont Rely on whats referred to as the Butt Dyno.... You just think its faster because you did something. Go get the car dyno'd, see what you have to work with. Then make better judgements as to what needs to be done after. In the mean time, do more research on whats available to your price range and what will suite you best. This is all my opinion though. All of us started somewhere, all of us thought it was cool to just go out and buy the sweet shiny new parts and throw them on.... Thats just part of the game. Then, if you research and learn (the internet is a great tool for this) you can figure out what and how to piece things together for a decent budget and make things work in your favor.
As stated, you will not reach 200 flywheel horsepower for your budget unless you go with nitrous. Your stock 170 is probably more likely to be 140-150 ish at this point if your lucky. An intake alone you might get an improvement of 1-2 horsepower, Header Maybe 3-5. Ect.... It will take all the common bolt ons you can put on it to maybe reach 175. And that will put you way over your budget itself.
Like I said, and cant stress enough... Do More Research.
Dafuq I just read?
gsrauto98
Post by gsrauto98 »
yes i must say RESEARCH is the best thing to do right now, figure out what exactly you want to do with your car, starts saving your money, and whatever you do DONT RUSH into things, take your time, set some goals, and go from there
CourtesyFlush
thanks a lot. i just dont have the money for the things all of you are talking about. i cant combine cams pistons and port n polish cause i dont have the money right now. but ill keep looking around and saving up some money.
tbrazzy-s3
Post by tbrazzy-s3 »
RyanA;191468 wrote:. The pimp ass straight pipe is actually probably hurting you. /QUOTE]
can anyone explain this to me? in theory i thought any restriction would inhibit power. straight pipes have less restriction correct? this is the whole reason im looking at buddy club's even though theyre ridiculously loud. just curious..
