Probably doesn't belong in engine tech, but I didn't want to put it in A/V, anyways... I believe my odyssey PC680 bit the dust. It was completely dead yesterday so I picked up a schumacher SC-1200A charger and charged it to full. Started right up, pulled out of my garage, and parked it on the street.
6 hours later I went to start it and got nothing but dim dash lights.. charged it up again. After the charge was complete the voltage tester on the charger read 14.3 volts but the battery continued to drop, 14.2, 14.1, 14, 13.9 etc every few seconds. Is the battery toast or how can I tell?
Hawker Odyssey PC680?
The battery will probably only hold 12-12.5v at rest. Check the voltage before you try to start it......and if the motor will crank, check the voltage while cranking (under load). The voltage probably drops like a rock.
chunney
Well it's a drycell and from what I read it should hold a constant 14.3 volt charge (which I'm pretty sure it did at one point)...
Yeah, maybe while the car is running. What he said before is right. 12.5 is pretty normal.chunney;169274 wrote:Well it's a drycell and from what I read it should hold a constant 14.3 volt charge (which I'm pretty sure it did at one point)...
luvmyhondas
how long did you charge the battery with your Schumacher? The dry cells like to have a really nice long slow charge after they've been deeply discharged like that. I've used the same style batteries for years and that's been my experience. That battery is basically the same thing that Stinger sells and that's according to them (back when I sold stereo stuff).
sounds like what phate's did before it went badchunney;169142 wrote:Probably doesn't belong in engine tech, but I didn't want to put it in A/V, anyways... I believe my odyssey PC680 bit the dust. It was completely dead yesterday so I picked up a schumacher SC-1200A charger and charged it to full. Started right up, pulled out of my garage, and parked it on the street.
Correct sir. I had something that was draining it though, then the cold killed it.N2HIFI;169452 wrote:sounds like what phate's did before it went bad
chunney
The access light in my hatch was draining it, didn't know it was on. I gave it an 8amp charge for 1 hr 45 mins... I'm pretty damn sure it's junk now. I have a stinger ordered since it's quite a bit cheaper. We'll see how that goes.
well send the odyssey back to them cause its under warranty and you can get it swapped for just shippingchunney;169499 wrote:The access light in my hatch was draining it, didn't know it was on. I gave it an 8amp charge for 1 hr 45 mins... I'm pretty damn sure it's junk now. I have a stinger ordered since it's quite a bit cheaper. We'll see how that goes.
Also what I just did. Cost me 20 bucks, and about 2 weeks, got a fresh new battery now. Oh, and some p:JDM swag.N2HIFI;169518 wrote:well send the odyssey back to them cause its under warranty and you can get it swapped for just shipping
