Prelude Turbo!!!!!!!!!!!!!!!!!!
zooyork22
yeah I know about Mahle Gold, but do you know they are COATED. Coating eventually wears off am I wrong? Never the less, the cylinder walls are fiberglass reinforced which are EXTREMELY fragile and will crack. You can run safely about 5psi I know for sure on the H22 though.
- "I like my honda like I like my women, D's instead of B's"
Jar Jar Binks
Jacques;26734 wrote: If this is to be daily-driven, it's a very good idea right off the bat to upgrade your pistons, rods, and sleeves to build up the bottom end.
nah... dont matter... the auto tranny will blow first
prelude98
I know a few guys that have run around 8-10 psi on the h22 with just upgraded pistons but you have to keep a close eye on things. Its alot safer to have the block sleeved. The auto tranny probably won't handle the abuse.
Mwprs37
The FRM sleeves are NOT the weak point on boosted H22's. Its a common myth. You find me one person that blew his/her motor due to the sleeves cracking. The ring lands on the pistons are the weak point. They can't handle much more than 250-275 whp. Search Honda-tech for info in the FRM sleeves if you don't believe me. There are SEVERAL boosted H22's on stock sleeves using Mahles pushing 400+whp... I'm currently building my turbo setup. I have about $2500 into it. I still am missing a turbo, clutch and injectors.
IMO to answer the original question, don't waste your time. Sell it and buy a 4th gen VTEC, with the extra cash use it to start your kit.
-Derek-
1993 Prelude VTEC...Boosted coming this spring.
x4
x4-
m6speed
true storyMwprs37;48981 wrote:The FRM sleeves are NOT the weak point on boosted H22's. Its a common myth. You find me one person that blew his/her motor due to the sleeves cracking. The ring lands on the pistons are the weak point. They can't handle much more than 250-275 whp. Search Honda-tech for info in the FRM sleeves if you don't believe me. There are SEVERAL boosted H22's on stock sleeves using Mahles pushing 400+whp... I'm currently building my turbo setup. I have about $2500 into it. I still am missing a turbo, clutch and injectors.
miz92lude
wrongzooyork22;48885 wrote:Just make sure to not boost too much since the sleeves are extremely week on the H22 and will crack most likely around 8psi or more. That I know based on other prelude clubs with people boosting at that amount and cracking the sleeve.
wrongzooyork22;48924 wrote:yeah I know about Mahle Gold, but do you know they are COATED. Coating eventually wears off am I wrong? Never the less, the cylinder walls are fiberglass reinforced which are EXTREMELY fragile and will crack. You can run safely about 5psi I know for sure on the H22 though.
rightMwprs37;48981 wrote:The FRM sleeves are NOT the weak point on boosted H22's. Its a common myth. You find me one person that blew his/her motor due to the sleeves cracking. The ring lands on the pistons are the weak point. They can't handle much more than 250-275 whp. Search Honda-tech for info in the FRM sleeves if you don't believe me. There are SEVERAL boosted H22's on stock sleeves using Mahles pushing 400+whp... I'm currently building my turbo setup. I have about $2500 into it. I still am missing a turbo, clutch and injectors.
modthesol
bumping over a year old thread FTL
TurboFreak
buy phates prelude and call it a day
Nik
Turbulent Motorsports
I have more torque than GOD!
MyfodoSi
+ a millionTurboFreak;120042 wrote:buy phates prelude and call it a day
RSXSLVR79
All these people above me are correct. H-series motors are not the best to boost, unless you swap lower compression pistons. The FRM sleeves burn up stock piston rings very badly, especially around 150k miles on average.
01 S2000 (Stock...for now)
