headgasket???
tommygun89hb
headgasket???
Post by tommygun89hb »
i have a z6 rotor justin if you want it im not sure if it will work on that distrib or not
HondaChild
headgasket???
Post by HondaChild »
andyjt;84213 wrote:Low RPM hesitation? High Load % hesitation?
low hesitation at idle like it will jump then about 7 seconds later do it again. but the tach does not move at all. and it does it when going from a stop, the car also has no power at all really.
ImageUnder RE-construstion
Know your roots.
HondaChild
headgasket???
tommygun89hb;84220 wrote:i have a z6 rotor justin if you want it im not sure if it will work on that distrib or not
I just bought a new rotor about 1000 miles ago. but thanks. If I need it I will let you know.
Know your roots.
andyjt
headgasket???
Post by andyjt »
HondaChild;84223 wrote:low hesitation at idle like it will jump then about 7 seconds later do it again. but the tach does not move at all. and it does it when going from a stop, the car also has no power at all really.
No CEL right. Possibly could be a bad ignition coil. How do the plugs look? Check wires, possibly high resistance. Cap? Rotor?
-Andrew-
'00 Honda Civic Si
'91 BMW 850i
tommygun89hb
headgasket???
roger the reason why i asked if you have a cel is because i had one onetime and it came accoss as a cranck angle sensor which is in the dist so i took the distrib apart and there was some wires in the dist that had the insulation worn out on it
andyjt
headgasket???
Post by andyjt »
tommygun89hb;84234 wrote:roger the reason why i asked if you have a cel is because i had one onetime and it came accoss as a cranck angle sensor which is in the dist so i took the distrib apart and there was some wires in the dist that had the insulation worn out on it
96+ Cars the crank angle pickup sensor is on the oil pump.
-Andrew-
'00 Honda Civic Si
'91 BMW 850i
HondaChild
headgasket???
andyjt;84231 wrote:No CEL right. Possibly could be a bad ignition coil. How do the plugs look? Check wires, possibly high resistance. Cap? Rotor?
Well I hope its not the cap wires or coil because all of those MSD items. and I just replaced the plugs about 1500 miles ago and they looked normal. I also just took the cap off no water but the distibutor was rather warm to the touch and the car has been of for about an hour.
Know your roots.
andyjt
headgasket???
Post by andyjt »
HondaChild;84249 wrote:Well I hope its not the cap wires or coil because all of those MSD items. and I just replaced the plugs about 1500 miles ago and they looked normal. I also just took the cap off no water but the distibutor was rather warm to the touch and the car has been of for about an hour.
Measure resistance between the plug wires. Also the resistance of the ignition coil. Hows the maintenance on other items: Fuel filter etc.
-Andrew-
'00 Honda Civic Si
'91 BMW 850i
tommygun89hb
headgasket???
hmmmmmmmmmmmmm hold on my car has been off for about an hour im going to go check the distrib to see if it is warm will let you know
HondaChild
headgasket???
andyjt;84257 wrote:Measure resistance between the plug wires. Also the resistance of the ignition coil. Hows the maintenance on other items: Fuel filter etc.
and I have never replaced the fuel filter but supposedly it was done when a new gasket was installed about a year ago.
tommygun89hb;84258 wrote:hmmmmmmmmmmmmm hold on my car has been off for about an hour im going to go check the distrib to see if it is warm will let you know
you posted just to say that. lol. just kidding.
Know your roots.
