ok...been working on this for a while now and i cant seem to figure this 96 teg ls out.... car has new plugs,, cap, wires, bug, fuel filter and screen.
the problem is that the car will start and sit and idle very smoothly, but it has absolutely NO power and just acts like its loading up when ur in it.
compression shows 175-180 across
fuel pressure is 38 when not running and 32 when running
has to be a spark issue??
the cam gears are lined up perfect and seems like it idles too good to be out of time. the car was out of time when i igot it but i thought i had it in time. i did it the old fashion way since i have to markings on my harmonic balancer. any help is appreciated!
trying to get the pos to run right
98ls1ttop
My Whips:
2006 F-150 larait 4x4 4 door too nice to drive
1998 Trans Am terror on the streets
1969 Chevrolet Nova my baby
1996 Acura Integra ls modified fart can
1994 Honda Civic daily driver
1987 Dodge 250 van (ghetto cruiser) 46,xxx act. miles
1978 F-250 built 400m c6 with dana's
1979 Firebird project car
whats your ignition timing like and , is this a swaped car?
also your cam timing may be off, do the marks line up across the timing belt cover? they are supposed to be horizontal to the motor not ground (motor sits in the car at a angle)
also you might have a vacuum leak also
map sensor and tps connectors switched?
98ls1ttop
it is not a swapped car and i have the cams lined up perfectly with the motor a the top of #1.
My Whips:
98ls1ttop
i just switched the map and tps and it didnt effect the shittyness of it at all, no better, no worse.....
its funny cuz i had the timing off, had both the cams in sync but a tooth off from what it was supposed to be (forward towards front of car) and it ran way better than it does not perfectly in time. it idled good and all, but i fixed the timing and now it just barely runs
My Whips:
are u using the white mark on the crank pulley and lining it up with the arrow on the timing cover?
98ls1ttop
there is no marks or stubs on the crank pulley, i was doing it by tdc on #1.
My Whips:
there are 4 marks on it .; 3 next to eachother and 1 by itself.
not always... i have seen one without the single mark before. be he cand still set piston #1 to tdc and get the correct timing.GUNMETAL SI;74174 wrote:there are 4 marks on it .; 3 next to eachother and 1 by itself.
my questions are did you remember to jump the jumper when you set the ignition timing and was the engine warm or cold when you did set the ignition timing?
98ls1ttop
i didnt set it with a light, i set it by tdc on #1 because there are no marks on the pulley....i went over it with a fine tooth comb. i adjusted the timing when the engine was warm. what would i need a jumper for setting it by feel?
My Whips:
