high idle
4Door
high idle
Post by 4Door »
Spork;65295 wrote:I fixed a 4500 rpm idle today... Goddamn I hate the FITV
X's elenty billion...
H.E.A.R.T
bradmoonshine1234
high idle
Post by bradmoonshine1234 »
i having and idle problem my self and i think that this post help a bunch thanks for the good info
high idle
Post by Gunmetal Si »
wow holy old thread bump
sir_dees1
high idle
Post by sir_dees1 »
I would try adjusting the idle adjustment screw on the throttle body,
1. Start engine and allow to get up to operating temp.
2. Disconnect the 2p connector from the Idle Air Control Valve aka EACV/IAC
3. Adjust the screw on the tb
4. turn ignition off
5. reconnect the 2p connector, remove the "back up" fuse in the under hood relay box
6. start it back up, re-adjust if necessary
sharpie
high idle
Post by sharpie »
sir_dees1;237324 wrote:I would try adjusting the idle adjustment screw on the throttle body,
problem solved....
about 3 years ago
high idle
this is the second time in as many weeks that a new member has joined and bumped an ago old thread. whoring owns you
