oil leak
solpower8
oil leak
Post by solpower8 »
i have a problem that if anyone can help it is well appreciated. I have put like 5 vtec soloenoid gaskets in and the seloenoid keeps cutting the gasket when you tighten it dont know what to do stumped
freakchris03
oil leak
Post by freakchris03 »
Are you over trq.ing. Wrong size gasket maybe? is there anything in the way?
97 Civic hatch...Sold :dead:
slow del sol
oil leak
Post by slow del sol »
I don't know about that exact gasket(I don't have vtec). But some gaskets that tear easily especially ones that have to twist, rubbing a little Vasoline on it (very light coating, no excess or globs) will lube it and allow it to move while it seats without tearing.
oil leak
Post by 90CivicEx »
Well like whats been said you might be torqueing it down to much but I find it good to put a layer of ultra black on the gasket also and snugging the bolts cause I think there suppose to be like between 10lbs and 12lbs and snugging them usually is perfect.
did that with mine like 3 months ago no oil leaks and runs like a champ.
solpower8
gasket
Post by solpower8 »
im not doing the work speed and sound is and they are even stumped by it i can put a new gasket in it and if it doesnt get cut by something while putting it on it only last like 2 days i have already put 5 in now and they keep using less torque each time but it still cuts it
