YCP- suzuki grand vitara pistons (bad ass low cost turbo pistons with stock honda bore size 75mm) The are aluminum and teflon coated and will handle 30psi and over 400hp 8.5:1 but will be 9.1 with my block head combo.
Hasting Rings- stock civic d series bore (and once again bad ass with low cost) handle 30psi and over 400hp
Tuner Toy rods- H-beams pretty much same as the eagles , just have some manufacturing differences to make h-beams clear with less machining, also come with arp bolts.
Also picked up a Y8 block just need to have the crank turned and then spec'd so i can order new bearings, then heat tanked and cleaned up then have the new parts installed.
i still have to order a full gasket set, but i already have headd studs on the way, the timing belt and misc other item here. i am thinking it should be realy to go into the car in about a month after i get the car back from paint.
ok now for some pics
