problems?
95_gsrfodo
problems?
Post by 95_gsrfodo »
ok guyz heres the deal been noticing that when coming to stops my car wantz to almost die and shakes like bad tune up..
was under the hood today noticed the timing belt had alot of slow it had enough to hit the plastic covers.. think its time for a new timing belt
but would that be causing the problem..
while changing the timing belt what bought putting my y8 head onto by d15b7 block? may need some help guys
willing to help also pay not sure im ready to get around another timing belt yet seeing that one almost took my damn finger
‎4 Doors = More Whores
problems?
Yes, the Y8 head will fit on the B7 block. Make sure you pull out the oil jet in the block so you have VTEC and if your going turbo, use a D16Z6 head gasket to lower compression.
95_gsrfodo
problems?
SilverStreak02;18748 wrote:Yes, the Y8 head will fit on the B7 block. Make sure you pull out the oil jet in the block so you have VTEC and if your going turbo, use a D16Z6 head gasket to lower compression.
thanx that kinda what i figured from the compression charts.. but im still comin up to like 9:1
problems?
91turbo;18751 wrote:thanx that kinda what i figured from the compression charts.. but im still comin up to like 9:1
Thats not to bad. Pretty low for a D motor.
95_gsrfodo
problems?
SilverStreak02;18757 wrote:Thats not to bad. Pretty low for a D motor.
well im just debating if it would be wiser to finish my y8 motor with low comp pistons and all or jsut put the head on my d15
problems?
91turbo;18760 wrote:well im just debating if it would be wiser to finish my y8 motor with low comp pistons and all or jsut put the head on my d15
I'd finish the Y8 and boost it. Then save the B7 just in case you blow the Y8.
