quarter mile times
ls hatch
quarter mile times
Post by ls hatch »
hi.. i have a 89 civic hb with a 91 b18a1.. almost all stock.. newer head.. i took the middle layer out of the headgasket,lightweight flywheel,new oem replacement clutch, completly gutted, no ac,air filter on throttle body,stock exhaust. accel plug wires, oem cap and rotor, ngk r plugs.. 13in tires. stocks.. curiouse what it will run.. and ideas?
i also have a friend with a 93 civic hb with a d16z6 short ram intake and full 2 1/2 exhaust.. stock manifold.. running a act stage one clutch and lightweight flywheel,13 in tires, full interier, no ac... any ideas on a time for it?
i have another friend with a 96 acura integra with a b18B1 full exhaust, header, cold air intake, full interier, short throw shifter, stock clutch and flywheel, 14 in tires.. any ideas for this car?
quarter mile times
your 'filter on throttlebody' mod is probably good for some power LOSS. you should put an actual intake on it.
quarter mile times
This is hilarious....
All three cars will probably be in the 15.5x-17.0x range. I'd guess 75-85mph trap speeds.
quarter mile times
Post by HardCore97 »
i trap around 88-89 with my ls swap. but i have the b16 tranny not the ls
Racecore.com
ls hatch
quarter mile times
Post by ls hatch »
haha thanks.. and the filter on the t/b is because the battery is in the way for a cold air intake.. and i bought the car w/o a filter even on the car.. so a filter is better than no filter lol.. how is the b16 tranny faster? everybody says that but i dont see how.. its quicker right? therefor you would shift more.. am i right? besides i like the ls it has a decently tall first gear for launches.. id like an even longer one though..
tmarsh
quarter mile times
Post by tmarsh »
The tighter ratios in the VTAAAAAAAAAAAAK transmissions keep you in your *ahem* power band.
You can speculate and benchrace all you want, but my hatch was able to beat a lighter crx because he had an LS transmission and I had the B16 transmission. Same engine, he had the weight advantage, and I still win.
'98 Grand Am: Wider is Better!
quarter mile times
ls hatch;208497 wrote:haha thanks.. and the filter on the t/b is because the battery is in the way for a cold air intake.. and i bought the car w/o a filter even on the car.. so a filter is better than no filter lol.. how is the b16 tranny faster? everybody says that but i dont see how.. its quicker right? therefor you would shift more.. am i right? besides i like the ls it has a decently tall first gear for launches.. id like an even longer one though..
first gear is the same on b series transmissions. the shorter gears make a big difference like tmarsh said. my brothers eg hatch had a b18b with upgraded valvetrain and crower stage 2 cams, higher CR pistons with an ls tranny and he couldnt pull on my car (97 coupe, ls swap b16 tranny with basic bolt ons) until after i shifted into fifth gear, which would be after the 1/4 mile so i would have been faster haha
Racecore.com
quarter mile times
Shorter gears equate to better acceleration. It also helps keep you in your powerband, as TMarsh said. Both help you get to the finish line quicker.
ls hatch
quarter mile times
Post by ls hatch »
ya.. i totally understand that. whats the rpms around 65? mine sits around 3k.. doesnt it get shittier fuel economy? and dang the b16 tranny makes a huge difference then.. isnt the b16 tranny hydro?
quarter mile times
Better solutions than a filter on t/b... with picture illustrations from two of my previous vehicles
make a (very) short ram.
OR...
get an intake tube that is made for the chassis
