Coolant flush?
Nat X
Coolant flush?
Post by Nat X »
As stupid as it might sound I have never changed my coolant (personally). I'm changing my hoses, one's leaky, and I'm just looking for any tips or tricks. It's a 97 integra GS by the way.
Thanks Nate.
deetz
Coolant flush?
Post by deetz »
we used to do this with older cars, but ya mix up a gallon of water with some baking soda, and pour it in your system and run the car at idle for like 10-15 minutes. then drain, flush it with clean hot water, and if ya look in the drain pan youll see all the buildup from inside your radiator and engine. it basically cleans the water system like seafoam cleans your fuel system. but the last car i did that on was myy 90 rx7.. not sure if its safe for hondas or not
~chris~
-scca setup 99 grand am gt
-85 cj7
Nat X
Coolant flush?
Post by Nat X »
Thanks.
Ineresting, I have never heard of this. Has anyone else?
ObsesionWitSped
Coolant flush?
Post by ObsesionWitSped »
I believe it's called a chemical flush. You can buy the stuff at a parts store, I think. From what I heard, it could help very well with rust and scale, altough it'll eat away at your water pump, so some people really recommend it using it when changing your water pump. :dunno:
Talking about Andy's drop:
Coolant flush?
Post by bildo16 »
hondas dont really have many cooling system problems if you do regular maint, t-belt and water pump. the stealership rec a drain and fill.
J8k'S CRX
Coolant flush?
Post by J8k'S CRX »
pull plug on radiator
let drain
stick hose in top filler
run water through for a few min
then close plug
and fill back up
(after you replace your hoses)
then bleed.(if ya have a bleeder)(if not then just start car for a min with cap off)
:stick:
Nat X
Coolant flush?
Post by Nat X »
J8k'S CRX;86176 wrote:pull plug on radiator
let drain
then close plug
and fill back up
Thanks I've got the mechanics of it down, but does anyone know if ls integras have a bleeder.
Thanks
Coolant flush?
hondas have bleeders on the system... on b-series I believe it is on the back of the motor right where the radiatior hose connects... if not, then it's on the front where the hose connects. should be pretty easy to spot.
HondaChild
Coolant flush?
Post by HondaChild »
Spork;86194 wrote:hondas have bleeders on the system... on b-series I believe it is on the back of the motor right where the radiatior hose connects... if not, then it's on the front where the hose connects. should be pretty easy to spot.
It should be right on top of the water neck.
ImageUnder RE-construstion
Know your roots.
