brake lights staying on..
zrs6v4
I have been out of town for a week, got home and drove the crx around for a couple of hours and parked it. I took my integra to work and came home a few hours later and my brake lights were on. I thought I left my lights on, but no and it wasnt a fuse either. I also check to see if the peddle was stuck or something but didnt seem to be so I unhooked the battery and left it alone. I cant figure the problem out, I was thinking of a pinched wire, a peddle switch(not sure, just told to check), or the problem is due to my master cylinder leaking a little.. anyone have any suggestions on what to look for? Oh and another thing is I had a 99 prelude where the tail light fuse kept popping b/c of some wiring in the cd player, I just put a new cd player in 2 weeks ago so Im thinking that could be the problem as well, but I am not sure.. thanks
99PreludeSh
andyjt
totally stupid question, but is the fluid full, or at least at the minimum line?zrs6v4;32359 wrote:I have been out of town for a week, got home and drove the crx around for a couple of hours and parked it. I took my integra to work and came home a few hours later and my brake lights were on. I thought I left my lights on, but no and it wasnt a fuse either. I also check to see if the peddle was stuck or something but didnt seem to be so I unhooked the battery and left it alone. I cant figure the problem out, I was thinking of a pinched wire, a peddle switch(not sure, just told to check), or the problem is due to my master cylinder leaking a little.. anyone have any suggestions on what to look for? Oh and another thing is I had a 99 prelude where the tail light fuse kept popping b/c of some wiring in the cd player, I just put a new cd player in 2 weeks ago so Im thinking that could be the problem as well, but I am not sure.. thanks
-Andrew-
'00 Honda Civic Si
'91 BMW 850i
'00 Honda Civic Si
'91 BMW 850i
zrs6v4
I didnt check, but I will.. the brake light switch is up under the dash and seems to be hard to get to from what I saw, although I dont really know what Im looking for.. can anyone help describe or tell me what to look for. I was thinking of buying a new one to replace it, then Id know what to look for. any help is much appreciated.. thanks again
slowagon
check that switch on your brake pedal....had the same problem on an old prelude and had to screw with that switch to get it to work but if it's not that then start tracing wires...
andyjt
Its grounded through the brake level sender in the m/c cap if i remember correctly.zrs6v4;32374 wrote:I didnt check, but I will.. the brake light switch is up under the dash and seems to be hard to get to from what I saw, although I dont really know what Im looking for.. can anyone help describe or tell me what to look for. I was thinking of buying a new one to replace it, then Id know what to look for. any help is much appreciated.. thanks again
-Andrew-
'00 Honda Civic Si
'91 BMW 850i
'00 Honda Civic Si
'91 BMW 850i
zrs6v4
alright thanks, Im lazy and havent messed with it much.
zrs6v4
good to go, it took 5 minutes. broken clip where the brake switch pushes into for those who care.. thanks
