sunroofs
civicex
sunroofs
well i don't know my problem is i don't know how to take it off without opening it.rickles8099;297017 wrote:why would you need a key to a sunroof? ive never heard of a sunroof that required a key to open it or shut it or for you to remove it.
PSN: DumbRands
sunroofs
What accessories do you need if you can power the sunroof motor itself?Sparky65;297032 wrote:I believe his problem is that he doesnt have the key to turn the ignition to power accessories.
You can use a separate source of power (i.e. drill battery) to power the motor(s) you need to.
sunroofs
that or take out the whole sunroof assembly... motor and mount and all.5thgen;297033 wrote:What accessories do you need if you can power the sunroof motor itself?
if you pull down the interior panel around the sunroof, you will see the bolts that hold the whole assembly in the car.
should take a total of 10 minutes to take out a whole sunroof assembly.
civicex
sunroofs
thats what im trying to do lol thanks didnt knowrickles8099;297034 wrote:that or take out the whole sunroof assembly... motor and mount and all.
PSN: DumbRands
