So yeah,
no thanks to the weather here in the Saint Louis area delaying the attachment of my new rims.. Yet without further waiting.
The Rims are on..
And the verdict is!!
I love them its that simple.
The quality of the wheels are outstanding. The attention to detail is def true JDM.
WedsSport SA-55M Black with Blue Painted
Offset: +45mm
Backspacing: 6.37" Bolt Pattern: 5-114
Yokohama S.drive 225/40 18
Weight: 18.6lbs
These are Skunk2 springs. Yes they do rub but only on huge bumps usually only on highways so not that often. I do think rolling your fenders is a good idea for this setup especially with the 225 width, not sure if the 215 would have been much better. Until my Skunk2 struts and shocks come in I'm using factory shocks and struts so that may fix the rubbing issues also.
The rubbing factor is not that bad, its not enough to cut up your tires but extensive use I would def consider rolling your fenders.
I usually have my any of my tire stuff done down the street here at Autotire and they were able to max out the factory camber settings for me. If I'm correct I believe he said he could manage to get -.25 out of the front and -2 out of the back. If I could bring in the front camber even more I would probably get away without having to do any fender rolling at all.
