Ok so I m helping a friend put jdm fogs in a 99 si. I have them installled but I'm stuck at the wiring.
I can't figure out the directinons. Any sugestions or help would be great
:wall:
fog light help
fog light help
60 seconds of searching brought me to this...
http://www.handa-accessories.com/civic/ ... lights.pdf
fog light help
rob knows how to use that magical thing called google...
Racecore.com
Racecore.com
fog light help
They are very hard to wire. You have to like screw down a ground and plug in a wire. Nearly impossible without specialty tools.
mlr198769er
fog light help
wow thats all im gonna say. One hot one ground. Wiring a light is not hard. Its like as hard as... well hang on..... hard as breathing ya ya breathing is a good answer
chaunce
fog light help
yeah couldnt figure those directions out. the plugs those directions said to use were both male so thats why i asked
mlr198769er
fog light help
if in doubt make a conversion plug... dont cut lol takes the value down on the car. Nothing better than buying a car that has haggered ass wiring
mlr198769er
fog light help
worst that will happen if you use existing wires is you run the wires backwards which will still turn on the lights. Is the high and low beams on the same connector a test light is like gold when doing stuff like this... nothing really bad will happen just keep some spare fuses laying around... when i got to junk yards i rack up as many fuses as possible and buy them all for a buck or two lol
chaunce
fog light help
fixed. there was a piece missing from one of the harnesses and that fuse idea is a good one for sure lol
