I need something grinded down (columbia, Mo).
adio3x
Post by adio3x »
Anyone good with using an angle grinder? I need my tail light bracket chopped off and smoothened out and I dont feel comfortable doing it myself lol. This is what I need done. If you can do this hit me up, or if your willing to drive down here, I'll pay for gas and the job.
from this
to this
~Mugen~ARC~HKS~Tein~Kaixen~Injen~Vis~JL~Pioneer~
vtecaddict
Post by vtecaddict »
ill be down there on Wednesday, i can stop by and look at it if its not done by then, i can probably do it.
adio3x
Post by adio3x »
sweetness
Post by mike93hatch »
bring it to jeff city and i can do it.
adio3x
Post by adio3x »
I can't transport it anywhere cause I don't have a van that can move it, and i can't drive it cause im not allowed on the highways lol.
adio3x;193828 wrote:I can't transport it anywhere cause I don't have a van that can move it, and i can't drive it cause im not allowed on the highways lol.
truck?
why arent you allowed on the hwy?
according the law i was able to run a true pocketbike on the hwy (on the shoulder).
Post by Capt'n Obvious »
this sounds like fun i might do it. if you were here i would say def for free but im kinda busy lately
slammeds2k
Post by slammeds2k »
Its easy man. Buy an angle grinder prolly two cutting wheels one grinding wheel and like 2 softpads. O and some S glasses fosho. all together it would be like 70 bucks and you have it for future projects... Cut it as close as possible to the seat supporting bar I would remove the seat. the sparks can melt that vinyl. I would also cover everything painted for the sparks can also melt paint and burn into glass and then later rust. After you have the most of it cut off take the grinder with two hands with the grinding wheel installed and apply small pressure to the mount untill the area is almost flush about a 1/8 of the surface. Then install the softpad on the grinder this one is for finesse with this installed you are going to apply small pressure on the bar let the pad do the work. When you use this pad on this rounded surface you are going to want to do a wrapping motion on the bar back and forth. This will smooth what is left of the welds in to the remaining surface.
99BlackHatch
Post by 99BlackHatch »
mike93hatch;193837 wrote:Image
I haven't laughed that hard in a while
SquadronOne.net
adio3x
Post by adio3x »
mike93hatch;193837 wrote:truck?
Noone I know has a truck. MO law, is you can't run anything 49cc's and lower on highways.
