Sub Amp Trouble
InspiredCg3
Sub Amp Trouble
hey guys i got a question, my amp seems to not be getting anymore power, and when it comes to car audio im pretty knowledgable so im stumped... i try making sure my power cord didnt have a crimp in it, replace the power wire fuse, both amp fuses, i re grounded it in 2 diff locations that were legit, i even re plugged everything back in and still no power is getting to my amp, i put a screw driver to the power wire where it connects to the amp and to the metal on the amp and it sparks so obviously that is a good current, so i dunno why it wont come on, maybe my amp crapped out?? any ideas anyone????
Club S2ki
Cars:
2000 dodge dakota SOLD
1998 Civc ex coupe SOLD
2000 S2000 WRECKED
1988 Audi 5000 Quattro T SOLD
95 Del Sol Si SOLD
'98 Accord Coupe DEP DD
04' S2000 Silverstone Metallic
:honda:
16vshelbyz
Sub Amp Trouble
Try putting a jumper wire from the remote wire hookup on the amp to the power cable. If it comes on then you just have an issue with the remote wire from the head unit.
87 Dodge Daytona Shelby Z
2.5L SOHC again, garrett t-3 50 trim, ARP studs throughout, 3" catless exhaust, FWDPerformance stage 5 cal, LC-1 wideband, HKS SSQV, A-555 trans, Black-Trax LSD, Chrome-moly midplate, 18" zeo wheels
Kolk1
Sub Amp Trouble
Have you actually used a Volt/ohm meter to check the power and remote for 12Vs? Do that first, and if it does, you have already moved the ground around, chances are the amp is shot. OR try seeing if it will power up with no speakers, and no RCAs attached to see if its possibly going into protect. I guess ill also ask, Does it have a protect light on it?
Hebrew Hammer
Sub Amp Trouble
bingo... take the meter... check power and ground.. then check remote and ground... if you have voltage to both then the amp is prolly shot
Kolk1;157687 wrote:Have you actually used a Volt/ohm meter to check the power and remote for 12Vs? Do that first, and if it does, you have already moved the ground around, chances are the amp is shot. OR try seeing if it will power up with no speakers, and no RCAs attached to see if its possibly going into protect. I guess ill also ask, Does it have a protect light on it?
Team Zapco, Second Skin, Audio Technology, Audionutz, Werewolf
gsrauto98
Sub Amp Trouble
That happened to my old amp, it came on but wouldn't put any power out. Your amp is probably shot. What kind of amp is it and how old?
93greengoblin
Sub Amp Trouble
ya i just bought a refurbished amp and this same crap happend so i opend it up and checked all the leads and that usually means the amp is shott send the amp back to the company thay can fix it
jmlaudio
Sub Amp Trouble
If you can just swing by and i'll bench test it for you. If it's broken we can fix it in house or send it out for you if parts are required.
"We are what we repeatedly do. Excellence, then, is not an act, but a Habit."
Kolk1
