Wtf
99BlackHatch
Wtf
Post by 99BlackHatch »
Research
research
research
SquadronOne.net
Wtf
RSXSLVR79;195371 wrote:wasnt that lude an F22A car? hence why the bracket doesnt work?
you told me i needed a rear tanny bracket from a 92-95 lude NOT a h22 prelude i got exactly what you told me and good luck on finding that in a junkyard
also the parts list is misleading also
http://www.preludepower.com/forums/show ... p?t=288172
11. I forgot to state that you need the Rear Engine bracket from the 4th or 5th gen Prelude, some H22's swaps are sold with Accord rear brackets. It is important that you note this down or AZ Races' rear engine mount will not fit.
it does not exactly state that you need a h22 mount just that you need the tranny mount from a 4th or 5th gen lude. It is very clear now that you need a h22 mount BUT it's not like i knew this when getting the mount i got
orange94hatch
Wtf
Post by orange94hatch »
i may have an extra rear bracket from the hatch in the garage. i will take a look. will that work?
07 cbr 600rr!
94 civic hatch- sold!!
95 fodo-wrecked. soon to be parted out!!
next project coming soon!
HondaChild
Wtf
Post by HondaChild »
99BlackHatch;195375 wrote:Research
research
research
lol. its not that he didn't do his research, he's been researching this swap for well over a year. It's just he was relying on the wrong people with the info. this is a very seldom done swap finding good detailed info on it is hard to do.
ImageUnder RE-construstion
Know your roots.
99BlackHatch
Wtf
I noticed that too when Chris grabbed info from PreludeZone or wherever and posted it. I can understand where critical pieces were not clarified.
SquadronOne.net
RSXSLVR79
Wtf
Post by RSXSLVR79 »
What happend to the one that came with the AJ's old car? That should have worked.
N2HIFI;195384 wrote:you told me i needed a rear tanny bracket from a 92-95 lude NOT a h22 prelude i got exactly what you told me and good luck on finding that in a junkyard
01 S2000 (Stock...for now)
Wtf
RSXSLVR79;195500 wrote:What happend to the one that came with the AJ's old car? That should have worked.
in aj's car i needed it to put that car together .. well to be honest it was identical to the one thats here because this one does not have the marks on it you get from a salvage yard
modthesol
Wtf
Post by modthesol »
N2HIFI;195526 wrote:this one does not have the marks on it you get from a salvage yard
with all my junk yard buying only half my stuff gets marked.
Wtf
Well a little update on this train wreck of a swap i am doing
so after all the "confusion" on what mount was needed for the swap and a mad frantic search to get the "right one" after taking a week off for personal/medical reasons i finally got a chance to tear back into the car tonight and install the rear mount and attempt to finish up the swap.
well they say that pictures are a worth a thousand words ... here is a picture of the "correct" mount installed
see anything wrong with this ???? other then the fact that the fucking swap mount is located too far fwd and the hole does not line up at all.... i see nothing wrong i mean it's supposed to be fucked up right .... WTH
okay well luckly i have cool tools to fix issues like this .. so i pull the mount back out and figure i can just enlarge the hole enough to get it to line up correctly...BUT there is a issue with that .. there is a welded nut on the other side that the bolt threads into ... well what now?
Ahh ill just use my impact and break the welds on it and break it off there ... okay done deal .. now simply take my bad ass new grinder with a carbide bit and do some work
okay now back in the car and just needs to be lined up and bolted down
okay lined up bolted down and FINALLY the motor is fully mounted in the car ..."correctly" lol
and i say "correctly" because the motor still sits wrong , shit hits everwhere , the mounts rub when the motor shifts around, the power steering pump is hitting against the core support and the low pressure side that runs to the resivoir sits on the core support with NO way to put a hose on it ... and this is just the start
:shakes head:
99BlackHatch
Wtf
This is the most practical swap ever... :angry7:
SquadronOne.net
