crxbrad;231011 wrote:This thing is still not running quite right!!!!!!!
It will start and idle...
Won't hardly rev though. If it does rev, it has a hard time doing it and backfires...
I've tried swtiching the MAP and TPS clips. No dif...
I've tried to see if there's any codes. I jumped the ecu w/the little blue plug and no codes. That is, if I did it right?...
What could this be?!?!?!?!?!?!?!?!?!?!
Please give me some ideas.
check to make sure the air temp sensor and iacv arent switched the iacv should have a black and a blue wire going to it. the air temp sensor should have a yellow/black... i dont remember the other wire color off the top of my head, maybe green/white.
if i am seeing it correctly in one of your pics i can see the plug with the blue and black wires going to the air temp sensor. it should be going to the iacv.
