1992 Civic Dx Sedan
Uncle_Willie
1992 Civic Dx Sedan
Post by Uncle_Willie »
Picked up a JDM D15b Vtec swap for it today for 300 bucks. Started cleaning it up a little. Removed all the electrical tape and wire loom and went through all the half ass wiring. Fixed everything and reloomed it, tucked everything i could. So far the motor seems to be in good condition, it was full of oil, pulled the valve cover and everything inside seemed to be great, spark plugs were good..etc. I think i might do a compression test on it tomorrow just to be sure of everything before i drop it in there.:rock:
When i got it home.
Deloomed the harness.
Harness back together.
Valve cover off.
1992 Civic Dx Sedan
l D15B Vtec l Tucked l lowered l Fit Sport Wheels
Uncle_Willie
1992 Civic Dx Sedan
Did a compression test today, got 180-190s across the board, seemed to be circulating oil into the head just fine. The linkage is bent and the driver side motor mount is blown so i need to get those and a set of axles before it goes in.
1992 Civic Dx Sedan
Uncle_Willie
1992 Civic Dx Sedan
Also picked up a pint of Phantom Grey Pearl and sprayed the Valve cover. It came out with a bunch of tiny bubbles and shit, the heat wasnt really helping the situation. Ill sand it down and respray it on a cooler day.
1992 Civic Dx Sedan
Uncle_Willie
1992 Civic Dx Sedan
Picked up a quart of Sebring Silver Metallic to spray the engine bay today. Gonna do the PGP valve cover, silver bay, and all polished accents. Hopefully gonna pick up linkage, a motor mount, and axles tomorrow.
1992 Civic Dx Sedan
Uncle_Willie
1992 Civic Dx Sedan
Bought shift linkage, axles, a motor mount, a torque mount bracket, and an ac bracket last night. Now need the rain to stop so i can get something done.
1992 Civic Dx Sedan
Uncle_Willie
1992 Civic Dx Sedan
Headlight harness' ran through inner fenders, fusebox mounted under the dash, dash back in. Ordered an aluminum radiator w/ slim fan, password JDM radiator stay, Ebay header, catalytic converter, HIDs, B&M precision short throw shifter, Shift knob, Duckbill, Clear Corner lights, Oil cap, and dipstick. Also picked up a rear disc brake swap from a teg today for 75 bucks. Went ahead and ordered some Energy Suspension trailing arm bushings for them before they go in. And bought a new Valve Cover gasket.
The next couple weeks will be like christmas everyday:oregonian_party2:
1992 Civic Dx Sedan
Uncle_Willie
1992 Civic Dx Sedan
Towed the car to the carwash and degreased/pressure washed the engine bay so I can start prepping it for paint. Headlight harnesses are all soldered/heatshrunk and wire loomed. Picked up an Engine hoist so itll be there when im ready to drop the motor in. Bought a propane torch and burnt the trailing arm bushings out of the rear discs so i can install my new energy suspension bushings.
Didnt run this side through the metal inner fender, it was 4 in the morning and I got lazy lol
I have friday, saturday, and sunday off so i hope to get the bay painted if the rain holds off.
1992 Civic Dx Sedan
thinkskater007
1992 Civic Dx Sedan
Post by thinkskater007 »
I am jealous of the time you have.
Uncle_Willie
1992 Civic Dx Sedan
thinkskater007;272114 wrote:I am jealous of the time you have.
Working 12 hour shifts FTW!! At least 3 days off every week lol
Update-header, cat, radiator and duckbill spoiler came today. Just waiting on HIDs and my radiator stay
1992 Civic Dx Sedan
Uncle_Willie
1992 Civic Dx Sedan
HIDs are in, not going to install untill the bay is painted and the front end is back on. Cleaned up the motor quite a bit, it was awful.
Before Purple Power degreaser and the carwash....
After...still not very clean.
A wire wheel does wonders!
Installed the duckbill.
1992 Civic Dx Sedan
