turbo or swap
92Accord
turbo or swap
Post by 92Accord »
i just cant decide should i turbo my 92 accord with its stock f22 motor with 260 thousand miles with a budget turbo, or go all out with the H22A swap and then turbo that? the turbo would be a budget turbo set up with as many used parts as i can get. and the H22a would be ordered from HMO http://www.hmotorsonline.com/shop/sc200 ... item=30016
opinions, comments, and advice i'm all ears
ObsesionWitSped
turbo or swap
Post by ObsesionWitSped »
Comments?
"Motors average 35,000 miles and..." <<<Funniest thing I read.
Talking about Andy's drop:
big pipe
turbo or swap
Post by big pipe »
you could do a budget dsm setup on you ride for half the price of the H swap, that would probably outperform it! that being said, how much power are you looking to make?
the turbo f with a dsm setup (cheapest route) is good for 250whp tops
the turbo H will only get you to about 300whp before you start to melt the pistons. the sleeves in a stock H bottom end dont allow for the use of forged pistons without a good re-sleeving$$$$$$$$$
i know of a guy making 640whp out of a built H22.
if i were you i would do a compression test to see if your current engine is up to snuff, then find a dsm manifold,16g,fmic,walbro, dsm450s, chipped p06,etc. the plus side to a boosted F is that when you blow your engine, your replacing a $200 motor instead of a $2000 motor, that and the H swap is a lot of work that N/A only puts down about 175whp
if your going to build either engine its gonna be ALOT cheaper building a F bottom end, and the end results are about the same
this space for rent
turbo or swap
Post by Phate »
Rock what you got. I cant keep my damn car on the road as it is, and im on 8lbs, stock bottom end. If you want to build it cheap, thats your own thing. I would save your money and do it right, or youll end up spending more in fixing everything that fucks up.
92Accord
turbo or swap
Post by 92Accord »
1
92Accord
turbo or swap
Post by 92Accord »
big pipe;105278 wrote:you could do a budget dsm setup on you ride for half the price of the H swap, that would probably outperform it! that being said, how much power are you looking to make?
where would i go for a compression test and what do i do if the current f is not up to snuff?
turbo or swap
Post by rickles8099 »
ill do a compression check for you, and if the current setup isnt up to snuff, either rebuild the motor you have or get another motor to build/rebuild/boost/na/or whatever else you decide to do.
92Accord
turbo or swap
Post by 92Accord »
cool when do you want to do it and how do you like your steak? rare, med rare, or well done.
turbo or swap
92Accord;105361 wrote:cool when do you want to do it and how do you like your steak? rare, med rare, or well done.
There is a crap ton of F22s at the junkyards around st. louis
92Accord
turbo or swap
Post by 92Accord »
and i can get one for like $200 right ?
