Anyway, here's the good stuff: I checked all the fluids and they were all clean and full. After sitting since 1990 or so (inspection sticker is punched 1989). The guy had some 2 stroke gas for his 4 wheeler sitting there so I put it in a glass bottle and poured a bit in the carb. I figured the oil would be a good thing to coat the cylinders since the car had not started for a good while. The engine started IMMEDIATELY and ran perfectly smooth. No lifter noise or anything. Exhaust needs replaced. Power windows kind of work when they want so the electrical will need to be gone through.
Brakes I was told the rear right was stuck but he had recently put on new wheel cylinders on the back. The front brakes interested me because they are factory 4 piston calipers on large discs.
Well, here are some pics of the car with a whole lot of dust on it. Like I said, the body is VERY straight and it even comes with all the hubcaps. Sorry, no full on side pics or anything as it's on a side bay on a barn. There is almost no room to move around the car...
